Has anyone managed to get psiloc's Total IR remote to work on the A925 (REL 30.80.12) ?
When i try to run it, it complains that the IR port needs to be de-activated.. even tho its off..
psilocs site seems to claim that this proggy works on the 925 tho...
maybe the software takes over the control of the IR port, so you might need to disable the control of the IR port by the default apps, and turn it off in the control panel?
...just a thought.... .... came from when i couldnt figure out how to get netstumbler to work properly... ^_^
The A925 is not supported. It was a mistake on their Website. It will be supported in the future though, but no date is set.
