When try 2 inst. quickoffice s60 and adobe acrobat s60, my n-gage error: Memory Low! Delete Some Data!. I've 128 mmc card with 70 mb available. How 2 fix it?
Isthere any kind of apps 2 view office docs? and pdf docs beside pdf+? and txt view?
I suppose you need to free up phone memory and/or close any running applications you may have in the background & then try again.
Quick office has to large installation file to get installed,the installation temp files are to large for the interal memory,
i tough someone sayd that once on some forum.
Hope this helps
TaloN
y not he use the msvdrivee n put it on the mmc..that way he wont face a problem..
fourdeen wrote:y not he use the msvdrivee n put it on the mmc..that way he wont face a problem..
He could use a SIS unpacker and put the app folder on the mmc
Here is the link to the sis Unpacker,
never tryed it tough, but u could give it a try,
:icon2: http://mitglied.lycos.de/atzplzw/
Or if you had a card reader, you put put the Quick Office installer on the root of your MMC, and install it via the Manager prog - worked for me! 😊
rulirahm wrote:When try 2 inst. quickoffice s60 and adobe acrobat s60, my n-gage error: Memory Low! Delete Some Data!. I've 128 mmc card with 70 mb available. How 2 fix it?Isthere any kind of apps 2 view office docs? and pdf docs beside pdf+? and txt view?
i was having the same problem with QO but managed to instal it finally. This is how:
1) Made a connection via bluetooth, double-clicked the .sis installer file. This gave a 'memory low' error but copied the installer to the 'c:\Nokia\installs' folder anyways.
2) Used FExplorer to Cut + Paste the installer to mmc root.
3) Went to Manager and selected 'instal' from 'Options'.
4) Installed to MMC
Voila!
I actually got this idea from one other post out here. Hope this helps you. All the Best.
Cheers,
FF
