OK, I have been playing Explode Arena lately and the d pad for the 7610 KILLS my thumb, and this is also the case with a few other games (although its ok for something like Sky Force mind).
Has anybody done either of the following
a) Designed a little 'control stick' which grips onto the dpad and gives you a little joystick on the top, I have seen this done for control pads in the past and usually works really well.
b) coded a program which will allow you to re-assign keys while the program is running (this would be awesome). This would give you complete control over which keys were in use for a game. So for example if u press 2, 4, 8, 6 this would actually press the button for left, right, up, down on the control pad.
Cheers for any help with getting my thumb a little less soar.
Nyx.
