I already did that once but know I have a new PC and I forgot how I did it the first time so... I have my MSI BT connected to the pc and installed the drivers. Now what? Which PC Suite version do I need? Anything else?
Thanks a lot!
Thanks a lot!
You need the latest version (whatever it is) PC Suite for Nokia 3650 (pick your phone from the drop-down list on http://www.nokia.com/pcsuite).
For using Bluetooth, you need to pair the phone with the PC and then create a virtual COM (serial) port, and enable that for PC Suite Connection Manager/m-Router
N/A wrote:You need the latest version (whatever it is) PC Suite for Nokia 3650 (pick your phone from the drop-down list on http://www.nokia.com/pcsuite).For using Bluetooth, you need to pair the phone with the PC and then create a virtual COM (serial) port, and enable that for PC Suite Connection Manager/m-Router
It depends on your Bluetooth software. Does it come with a User's Guide or at least on-line help you can consult?
I have creates the virtual ports but the problem now is that the phone is not being recognized in PC Suite.
