i have heard that the 1000mha battery can just fit if you remove the steaker, did anyone try it??
battery for 7650 more hours??
I've got a 1100mha battery & it fits in beautifully.
can u please give me the model number of the 1000 mha or 1100mha battery u used, would like to try it myself
[quote="spy_2002"]i have heard that the 1000mha battery can just fit if you remove the steaker, did anyone try it??[/quote]
do you mean the one that comes with the Nokia 8855 ?????
if yes then you cannot put the battery slide cos it slighty thicker than the blb-2
Here's the site where I bought mine from.
http://www.1st4mobileaccessories.co.uk/batteries.shtml
please post battery number id make or something so we can all try and find one nearby.
What battery does the 8310 come with
coz the battery that came with that, fits into the 7650 and its a 900mAh isnt it?
[quote="spy_2002"]please post battery number id make or something so we can all try and find one nearby.[/quote]
apo auto link agorasa thn mpataria pou leei o filos poio pano..teriazei tzami sto 7650 kai einai 1100mha
mou thn esteilan spiti kai xreothika 17.5 lires aglias (28.24 euro)
sou thn synhsto
