Now how do i format a phone which is mmc locked.
The three key worked for the phone but not for the mmc .
Any suggestions??????
6600 format a locked mmc
See your duplicate post to which I replied. In short: no code, no access.
same problem.. is there any chance to unblock MMC ive tried using seleq, fexplorer... but no luck!
i need help! thanks in advance. :icon14: 😉
The answer is still "no".
ripley wrote:same problem.. is there any chance to unblock MMC ive tried using seleq, fexplorer... but no luck!
nabhan wrote:
Please tell me about locked memory card formatting. If other solution is possible please send me answer and also screensaver problem, I have removed the sofware of screensaver but many time an error is occured from screensaver hidden file and gallery not opening and file manager is also not working properly. Please send me the solution of these cause.
lake wrote:Now how do i format a phone which is mmc locked.
this my first time in this fourm hi to all
u can format locked mmc by using nokia communcator phone
I formated more than 20 locked mmc.
follow the steps:
1-start the phone with working mmc
2-let it to be ready to format
3-remove the working mmc and insert the locked mmc
4-press format
5-it will format the locked mmc
good luck
M. Rizwan Ali Bhatti
teleword wrote:Please tell me about locked memory card formatting. If other solution is possible please send me answer and also screensaver problem, I have removed the sofware of screensaver but many time an error is occured from screensaver hidden file and gallery not opening and file manager is also not working properly. Please send me the solution of these cause.
Install Seleq and go to C than system than copy mmcstore to Pc by infrared or edit it with some text editter your password will there only in case you have locked mmc by your own phone. Formatting will remove all data and there is no hope except going to Service center.
You need to format your phone but you will have to save all data and contacts some where else.
Use
*#7370#
to format phone.
Phone will ask for lock code.
Default code is 12345
remo your MMC before formatting for better results.
Also you will have to wait untill phone starts. Some time after formatting phone do not accept SIM not to worry and restart.
BYE
is there any other technique apart from:
1) using backep up dat
2)mmcstore file
to unlock an ncp 256 mmc on a nokia 6600.
if so please help.
thanks.
format locked mmc to mobile 9210 i :icon14: :icon14: :icon14:
