I've a cracked apps. When inst. it, get expired. Then I change the year of my n-gage to be year 2020 (my alarm that has been set using power notes apps for symbian is running) then inst. it again. When the apps is trying to put him self in installer (tools+manager), my n-gage get error msg: "Installer: system error!" then hang. I try to inst another apps, get same error msg. I try to use fexplorer apps to browse my n-gage files. It seems that the file appinst.ini in c:\system\apps is missing and when i try to access that directory with fexplorer, the fexplorer apps is closed quickly (app. closed fexplorer!). Any body can help me?
system error!
rulirahm wrote:I've a cracked apps. When inst. it, get expired. Then I change the year of my n-gage to be year 2020 (my alarm that has been set using power notes apps for symbian is running) then inst. it again. When the apps is trying to put him self in installer (tools+manager), my n-gage get error msg: "Installer: system error!" then hang. I try to inst another apps, get same error msg. I try to use fexplorer apps to browse my n-gage files. It seems that the file appinst.ini in c:\system\apps is missing and when i try to access that directory with fexplorer, the fexplorer apps is closed quickly (app. closed fexplorer!). Any body can help me?
Thats what u get for installing cracked apps. :icon13:
lol
Now my mmc is formated 7 times, but there's nothing i do with my n-gage internal 4mb memory, so the apps's list is still in the manager and i can't remove it. How to install the o/s again in my internal memory (like want to install windows again-in pc)?
The point : how to fix the errors in my n-gage?
Pls hlp!!!
rulirahm wrote:Now my mmc is formated 7 times, but there's nothing i do with my n-gage internal 4mb memory, so the apps's list is still in the manager and i can't remove it. How to install the o/s again in my internal memory (like want to install windows again-in pc)?The point : how to fix the errors in my n-gage?
Pls hlp!!!
Format the phone. Search the forum.
Pls hlp!!!
Type *#7370# on your phone's standby screen (where you can see wallpaper, operator name etc.) and follow the prompts. This will format your phone's internal memory.
