musichelle wrote:judging from most of the posts here, i am starting to think that the X is supposedly something great, but unfortunately failed to live up to its name..my question now is, is it REALLY that bad..? the praises are quite few, i have to admit. i am considering to buy one, but posts here make me think more than twice. we all know its quite expensive, and i'm looking for a phone which is well worth the money i'll shell out for it. but a number of people had their X for some time and ended up returning it.
thanks in advance for your opinions.
As has been said before. Most things depends on what you're coming from. If you're spoiled by especially Sony-Ericsson phones whom have a great symbiosis regarding phone/sms/mms facilities adn a generally very userfriendly U/I then you might be disapointed. If you come from Nokia phones then I suspect you will like the Sendo X.
My problems with it where awkward bluetooth implementation (the lack of vital profiles urged me to return it). I thought that in this respect my former T68i had a more confusing setup (more menu-items to wade through) but generally behaved more stable with regards to Bluetooth.
The u/i is not as intuitive as I would have liked. For instance I missed calling tel.nos. embeded in SMS messages in a convienent way. It apears (though I can't try this anymore) that it IS possible using the options menu when viewing SMS-messages. Unfortunatly this is not obvious and I didn't even saw this mentioned in the manual.
The phone sometimes behaves odd. For instance it's not uncommon that a phone resets a few times at power-up before you get a welcome screen. To name just one.
What I do like. The Sendo has IMHO an excellent audio subsystem. It's speakerphone is amazingly loud and clear. Most functions are fast and responsive though because of its odd behavious ocasionally things start to cralw for an unknown reason. Usually its a fast phone (unlike the affordmentioned T68i). The screen is very good. Though not the best in direct sunlight which shouldn't be a problem in Brittain I supose 😉 IMHO its a very good and aparantly large screen under most circumstances. I think that Sendo had better focussed their PR-campaign for this phone on its excellent sound system instead of that glorified !Now screen. Because you can sell this phone by letting ppl enjoy the speakerphone IMHO.
I never used T9 input since my motherlanguage is Dutch and there's no Dutch T9 build in. Though I didn't like the keypad at first, near the end of my ownership I started to like it. The keys are not bad though the upper row with the navigation-pad gets confusing. The answer and hangup key have other keys besides them. You sometimes press the wrong key.
The case is made of plastic but some parts are covered with an brushed aluminium panel. This looks very cool but i've discovered that the phone is very fragile. I bumped it once and the panels got bend on impact. I also wonder how long it takes before the large panel at the back will come off (it reminded me of my old ZX Spectrum). Since you have to remove the backpanel to insert or remove your SD card I believe the rear panel will show most wear and tear. That rear-panel is also the part that creaks though it did seem to fit nicely.
The Phone when used in video-mode has a vivid viewfinder. Almost showing things real-time. Though the movies have definitly less fps. Both camera and video-mode are fine for its vga-sensor. It even has a bright white LED to iluminate dark places.
The Sendo website still gives users the ability to (freely) upgrade firmware and there's promise to provide some applications (theme manager for instance). This is a bonus. Unfortunatly much software available now is being updated for Series 60 UI v2 while the Sendo uses v1.x This means that many apps won't work on this Symbian phone. Most have tiny problems ranging from no sound for games to interference with normal phone operations. So if you want a software loaden device appart from Java apps the Sendo X is IMHO not a good bet.
Another good point. The Sendo X is atm one of the cheapest so-called smartphones. The package even contains both the datacable (USB) and the PC-connectivity software. So if price is important then the Sendo X gives much bang for the buck.
To sum up:
minus points
-Older platform (might be restricting in the future unless Sendo X sells well)
-certain UI parts not intuitive
-odd behaviour
-casing is quite fragile and creaks
plus points
-great screen
-amazing sound (especially speakerphone)
-fast and responsiveness (most o/t time)
-necessary accesoires included in the package
-free firmware and software upgrades for now.
-cheapest smartphone atm
Hope this gives an idea,
EPDM
