problem with quickoffice
2 replies · 1,462 views · Started 12 October 2004
hi i have installed quickoffice in my 7610 but somehow, only quickword seems to work fine. quickpoint n quicksheet does not start at all, however when i installed a separate quickpoint it works again. quicksheet cant starts at all. anyone has this problem?
i only manage to get quikword to run, however if you manually select the .xls or .doc files, it'll automatically open.
BUT i face another problem is that sometimes i need to restart the phone in order to view a file. seems like the quickoffice does utilize lots of memory to operate
Same exact problem here. Igo reports their software is not compatible with 7610 but I have also gotten quickword to work on mine. However, I am having the same probs as ocphangaz.
