Hi All,
Recently I have installed a 128 memory card in my 6600. It was already loaded with number of softwares, games, images, etc..
When I try to open the images folder of memory card through gallery, It gives an error 'Application closed AppArcThread'. After that my mobile becomes extremely slow. When I power off & again on, it behaves normally.
My question is, why my mobile gives above error & becomes slow after that?
TIA
Mahesh K.
There images are .gif there is a problem in the image files just delete that files.
I don't much but some files giving me the problem they were working find on pc but not on phone.
So i deleted the files.
.gif files not create problem at all.
Yes, .gif files are surely not the cause of problem. But the problem must be due to one or more image files present in that folder. Because When I deleted all the files from that folder, it's working fine. No error.
I had copied all those images on my PC before deleting them from my mobile. I tested those image files on my PC & they are fine. Not corrupted. Few files are of very big size i.e. 1024x768. I think those files are the cause of problem. What do you think?
Mahesh K.
Yah that must be cause either the file is corrupt or its too big.
