found a short cut :D
8 replies · 3,247 views · Started 13 October 2004
Check this out, I found this Shortcut on my Sendo X.
It may be in the Manual but really I never reed the Manual 😮
If you go open an App like let�s say Contacts then try holding down the
Menu button next to the Green Phone button next to the Curser Plate.
A small tab will open on the top right side where you change software
Like Command Tab on Mac or Alt Tab on Windoz.
Oh yeah, has anybody found a way to use the Phone and send SMS over Addressbook on OSX?
Shaggy
Thanks for the tip, Shaggy. I hadn't spotted that one.
And I've had no luck sending SMSs from Address Book either - the option appears in the menu but it is greyed out. Does anyone know if this works with other Series 60 phones?
Well it does work with my Girlfriends Sony Ericsson T610.
But again that Sony Ericsson.
Shaggy
Am i missing something or am i having a bad brain day?
Can you explain what you are trying to do with the phone? Is it through a pre-installed application or a 3rd party application on the phone?
Shaggy wrote:Check this out, I found this Shortcut on my Sendo X.
Shaggy
man, that's a basic tool in symbian software 😃
and if u press "c" buton u can kill the aplication.... 😮
good "discovery" 😃
give him a break, he was trying to help
but yes, it's a basic symbian option like in windows :icon14: 😉
euphoriauk wrote:I agree with Speedman!
Common Barros give shaggy a break!
hey didn't mean to ofend 😊
just loling a bit 😊
sorry 😎
