hey everybody, i hope that somebody will be able to help me with my problem. i woke up today as usually on an alarm on my nokia 3650, turn it on as usually. but i realized that something was wrong, the profiles were little bit messed up. so i turned the phone off, and then turn it on...unfortunately ot did not go on, it just showed the nokia logo and brightened the screen. but then it faded out as if it was turning off and it did turn off. what could have happened? the phone was running fine yesterday😞. thanks for your help
Nokia 3650 big problem
Unplug AC. Remove battery. Remove MMC. Replace battery. Connect AC. Wait until charging begins. Turn phone on.
If it doesn't turn on. Try another charger and/or another battery, if possible (borrow from somebody, for example).
If those don't help, a trip to the nearest Nokia authorized service center is probably in order.
unfortunately, that did not help :frown:
I think Your Phone Need a RE-Flash Now
Contact Nokia Service Center.
me too face that problem many times. its boots me sometimes when i m on wap. it happens in my 6230 and 3650!!!
did you get it to work? if yes, what did you do?
