Sis Applications
1 replies · 2,499 views · Started 13 October 2004
I Have A Bunch Of .sis Aplications That Where Designed For The Sony Ericson P8/900 I Started To Install Them On To My Nokia 6600 And It Told Me It May Not Be Compatible With The Phone I Told It To Install It Which It Did. The Icons For The Applications Came Up But When I Try To Open Them It Appers For Second Like Its Opening It But Then It Does Nothing.
how Can I Get These Files To Work?
Just tell me can u run a disel car on pertol.
U can't Work these files in Nokia 6600.
They are made for S.E 800/900(UiQ) and can't be work on Series 60.
U should try the sis file which are made for series 60.
