Help! "Transfer/Send" a program........
2 replies · 1,453 views · Started 14 October 2004
Hi i will appreciate if anybody can teach me to "transfer/send" a installed program from my N6600 to another N6600.
i had FExplorer and SeleQ, but don't know how to get started............. 😕
Wish someone can guide me along? Thank you very much.
0: If the program doesn't have a built-in feature for it (some applications can send a copy of themselves to another phone), then...
1: Find all the individual files (e.g., under c:\System\Apps or where ever it was installed) and make a note of the complete path (where each file is)
2: Send the files one by one.
3: On the receiving end put all the files where they should be, one by one.
The best and easiest way is to get the original installation package (.sis) instead, rather than doing it the hard way.
N/A wrote:0: If the program doesn't have a built-in feature for it (some applications can send a copy of themselves to another phone), then...
Hi N/A, thank you very much. Now i understand the process to transfer program......
Many thanks to you............
