Hi.
I just got myself a used SE P900 here at work and fooled around with bluetooth, sending and receiving files from other people.
A) Problem is, when someone else sends me something I don't get a prompt wether or not I want to accept the incoming files, it just accept it automaticly. I guess there's some settings for this or whatnot but haven't been able to find them yet.
B) Is it possible as well to boot into safemode or something like this cause I installed an application and when I try to uninstall it it just says "Access denied" and goes back to the "desktop". I read somewhere that the solution to this sometimes would be to remove it in safemode but haven't figured out if I can do this or how to.
C) What exactly happens when I run the "Master reset" in the control panel under "Other"? I don't lose any themes or applications installed do I?
