Hi Ppl
I have a P900 Sony Ericsson, and wish to be able to receive emails on it, while away from my desk. I believe it is possible to receive emails on both PC and P900 from an exchange server. However, we do have a firewall in place. Not to sure how to go about connecting the P900 to the server via the VPN. Does any1 have any ideas, on how to do this, or where to begin.
Cheers
Not sure if this will help but I tried Smartner Duality software (www.smartner.com) and it works well, I set it up in about 15 mins, no change to the firewall at all. I am using the trial software and there is no snyc with the calendar at present but apart from that it works very well and as I said easy to install.
I have the same setup Exchange / Outlook 2003 and P900
cheers
juicepig wrote:Not sure if this will help but I tried Smartner Duality software (www.smartner.com) and it works well, I set it up in about 15 mins, no change to the firewall at all. I am using the trial software and there is no snyc with the calendar at present but apart from that it works very well and as I said easy to install. I have the same setup Exchange / Outlook 2003 and P900
cheers
Hi there, I tried to set up the smartner duality on my p910i, but when it tries to open the first gprs connection to complete the installation, it gives me back an error message (error -33, can't create a connection).
I was wonderingif you had the same problem and if u solved it; i saw on many forums others having the same issue.
thanks a lot
Luca
