Well, i cant delete my message reports, not the log but the reports.
I know i can send sms/mms without reports but i want to know if someone can delete the reports ?
thanks in advance.
thanks in advance.
open the Log then select option--filter--Reports--then delete from here
there is no filter reeports option in my log screen, is this correct?
Menu -> log -> joystick right -> options -> clear log
so that deletes the delivery reports as well? I would never have guessed that one thanks.
[quote="Pichu"]open the Log then select option--filter--Reports--then delete from here[/quote]
It works, but no filter for reports, only delete all log 😮
thanks 8)
