hello and sorry to fill your forums with another newbie request ... I just got my nokia 7610 and I am looking for some good software for it (free if possible).
Is there a thread in this forum with just a simple list of all software/games available for symbian os ?
Which software would you recommend or find very fancy yourselves?
Is there a remote control software for Nokia 7610 ? (i would guess no since it doesn't have infra red)
thanks in advance
Well the best free software i can suggest u is FX EXP from www.gosymbian.com
and u r right Ir Remote can not work on Nokia 7610.
and u download lot of free themes too.
what's exactly FX Exp doing ? there is no site description at all ! 😊
It is file Exp, Screen Capture, and also put images to operator log, having a reboot function. etc
the newest handsfree's from nokia for example hs-31 doesn't works on my phone... 😞.. what i can do ?! to get a new software... to update my symbian. what pls help :frown:
hello!can anybody help me pls...i have camera fx 2.60 on my 7610 and i need the unlock code..mu imei is :35338-80001-97428 pls help
hey guys i want to ask i have nokia 7610 and i can't use Psiloc_Total_irRemote???cause i dont have infrared on the phone ?? 😞( can i upgrade ifrared on this phone ?? i hope there will be my answer thanks all ..
You can't use irRemote and you can't upgrade your phone to have IrDA. Honestly, I used irRemote on my 3230 and I can't say it worth buying it. Active distance was around 1.5 meters and it was easier to use my toes to switch channels or change the volume. It was a nice thing to play in TV stores though 😉
