Anyone have succesfuly try Active viewer http://www.simeda.com/activeviewer/downloaddemo.html
remote control fo your computer on your 7650 😊 VNC 😊
SO i have try it and no way it doesn't work for me 😞( maybe someone have any tips or help ?
my vnc server works fine I have tested on another computer, I have no proxy no firewall
It worked fine for me! Just installed it, made the settings and it worked from the first time!
If you are using the vodafone GPRS service you will find that only very few TCP/IP ports are allowed out of their gateway, which is a pain in the butt... This might be true of other GPRS services...
If you set up active viewer using their java HTTP proxy connection you will be able to use it fine...
Damn this is one very cool application
runs off to download and try..... 😊
Hi all ....
I'm not able to connect from my phone. Server is set up ok, and can access through other pc.
Somehow, the phone doesnt seem to connect. No errors displayed. Just sits there. Have tried it over both GPRS and also BT. No Luck.
Any suggestions?
Guess i am a little too late for download the demo version of this appl.. the website have remove it link for download but only to buy the software.
Does it have any proxy setting if i connect via dialup or GPRS connection which require to have proxy setting?
