fm on nokia 6600 ?
5 replies · 1,533 views · Started 15 October 2004
frnds,
can i listen fm radio on my nokia6600.
any software for this, give me clue. pls help
diwanji wrote:frnds,
Try searching for avec radio, its a radio stream using gprs.
Not too good quality though and it depends on your operator if you'll be charged per kb or what. Additional fee to some. 😃
Diwan Please don't repeat post the same post u have posted before tooo
so take care next time.
Does any1 know if this radio program needs http protocol to work ?
my provider give me a GPRS WAP unlimited pakage for only 2.50$ a month, mainly used to enter to any wap page in the net, but I can also DL files (mid's, pics...) by entering their URL into the phone.
Do U think this radio program will work with this kind of pakage ?
Kamalayan wrote:Try searching for avec radio, its a radio stream using gprs.
Thanx, but it does not work.
something else that works pls.
diwanji wrote:Thanx, but it does not work.
Contact your operator if it alows you access outside other wapsites if it doesnt then your operator may charge you for accessing wapsites or streaming contents or may have special configurations.
