Re Contacts
3 replies · 1,827 views · Started 05 December 2001
Dear All,
I know this subject might have already been discussed several times in this Forum, but It seems that I cant find the answer to my quest...
My problem is the following.
Due to technical reasons, I had to Format both the 9210 and the MMC card. Of course, before, I made a copy of my Calendar & my Contactcs. After that I have reinstalled all necessary progs & apps, I want to reuse the Files I saved before.
Concerning the Calendar, no problems at all. I just want to Calendar, and used... More Options - Import... and all is okay. Plus this means that I do not use a lot of memory Space in having my calendar in the 9210.
For all concerned, I have at the time being a total memory in use in the 9210 of 855 kb, with a lot of apps and extra staff installed. Not bad !!!
NOW, back to my problem...
I am trying to get the Contacts I saved (in a file copy) before, to be back in their correct place... It seems that I do not manage at all this operation. I try to Move, I try to copy and paste, I try to cut and paste, I try to rename the file, etc... I try topopen the saved one directly...
But no success. Okay, I could spend some time to rewrite all my contacts, but I am sure someone will come up with a full solution. So can someone help ???
Ouf! That's all for now...
Best Regards & Filakia to all from Sunny Greece.
Seems that your new contacts.cdb is in use...
Copy your old/original contacts.cdb to <B>D\system\data</B>, and open "contacts" from 9210.. there you have now new database called "contacts" in MMC.
Goto there and "select all" and copy to..(Shift+Ctrl+C) to contactbook or whatever it's called in there (i have finnish 9210)
Hope it helps....
Regards
If you have made a back-up off your new setup, otherwise do so. Then you can replace the file in your back-up and then restore it with your back-up manager.
The back-up manager closes all the files that are in use so this should do the trick.
THANKS 2 BOTH OF YOU...
IT WORKED !!!!!!!!!!!!!!!!!
I REALLY OWE YOU ONE OR TWO, DEPENDING IF YOU DRINK A LOT...
REGARDS TO ALL 7 AS USUAL FILAKIA (MEANS KISSES IN GREEK).
