3650 help
3 replies · 1,635 views · Started 15 October 2004
help please. java applications cant access gprs, for eg if i dpwnload any j2me messenger its doesn't connects, it just shows connecting. i have checked my gprs connection, its fine, do u all think its software problem? my software version is 2.50. please help should i upgrade my software? :con?
wapgeek wrote:help please. java applications cant access gprs, for eg if i dpwnload any j2me messenger its doesn't connects, it just shows connecting. i have checked my gprs connection, its fine, do u all think its software problem? my software version is 2.50. please help should i upgrade my software? :con?
I hope your gprs connection is really ok cause that seems to be the thing that limits your access to wap. Maybe you could try formatting first then re configure your GPRS/MMS settings and if it still doesnt work, take it to your operator and hand them over the problem. 🙄
yes i formatted it, its same just shows connecting. should upgrade my firmware? cos my software version is 2.50
Plzz... Help Me Where Do I Found Free Application For My Nokia 3650 Kindly Reply All Thnkzzzzzzz
