6600 wont send messages anymore
4 replies · 2,518 views · Started 16 October 2004
Hi
My 6600 has been working fine for about a year, but today and yesterday its just not sending messages, it retries several times then says "General Error: Memory full close some applications and try again" I've taken the battery out and put it back in and made sure nothing was running with a proccess manager (cant remember the name)
Anyone got any ideas ? This is _very_ annoying !
Half
It may be that you have too many messages stored. Try deleting some older ones.
If you still have the same problem, check the mail folder with FExplorer or SeleQ. Sometimes 'ghosts' remain in the memory, even when the message has been deleted in the normal way.
I've had the same problem and have tried resetting the phone but its still not working! Have you solved your problem? I cant find the mail folder either 😞
TRY THIS ONLY TO RESET YOUR 6600.
Normal Reset (*#7780#) : Restores ini files from rom but preserves user data (photos, 3rd party apps etc)
Deep Reset (*#7370#) : This reformats completely the C: drive. All applications and files stored on this drive will be lost and clean default files will be rewritten.
Full phone format on a 6600
If any of the problems listed below is happening to your phone:
A. Blank screen phone unable to boot-up.
B. Phone is only able to boot-up to "Nokia" screen (may flash "Nokia" 4 times also).
C. Install a program but unable to uninstall it.
D. Unable to delete certain files on C drive.
--- WARNING: This will ERASE EVERYTHING on your phone ---
If you have any files that are important to you, make backups.
1. Make sure you phone is fully charged.
2. Backup your contacts list and personal files to MMC memory card (if possible).
3. Switch-off your 6600 phone.
4. Press and hold these three keys together
-Green dial key,
-Star key (*)
-Three key (3)
then press the power on/off to swtich on the 6600 phone.
Do not let go the three keys until you see the "formatting" screen displayed
5. After a few minutes, the format will be complete. Your 6600 will now be at its original factory settings.
GOOD LUCK !!!!
