Hi all,
I checked the "Memory details" for the memory card and it's showing 40 mb used and only 21 mb is free. But the details are like this:
images: 3266 mb
sound files: 7600 mb
video clips: 1175 mb
applications: 1955 mb
mem in use: 40mb
free: 21mb
????? It all adds upto only 13996 mb! What happened to the rest?? Why is it showing 40mb used??
Please help me out on this....Any help would be greatly appreciated.
Raaj.
Hi Raaj
Well u must be using some themes, application
They are not inculeded in it.
just download Fx Exp and see the internal hidden folders.
Thanks, vicky!
Yeah, i have lots of themes and been removing some now. Got back upto 27mb. Will keep trying.
Thanks again 😊
Raaj.
yeah me too i've got the same prob.Got a 64MB RS-MMC bought with the 6670 phone.Turned on the phone and saw capacity 61MB.What's that supposed to mean.As if the surprise wasn't enough.Download some apps and calculate it but yet it tells me that i've got 2709kb left while i calculated 35mb used.What's this?
And yeah what application can i use to check verything on the system specifically.
thanks!
i was wondering if the deleted files are still added to the mmc.Wher do they go to after they have been deleted?Do they just varnish.I need to know this it keeps bothering me as the capacity of the mmc keeps reducing.
Use Fx Exp from www.gosymbian.com
Don't Delete that file which u don't know or u don't hav any infomation abt that file.
I had the same problem as raj
Wot happened was i had files on my mmc that the nokia didnt understand and it took memory up but didnt show it...
just connect to your phone with your pc and delete the files off
