Hi everyone!
So, I have a Nokia 7650, but it's memory is getting stacked with text messages... I don't like deleting them, and I have more then 750 of them right now... I also have a USB Bluetooth Dongle, which I use to send my images from my cellphone to my laptop...
Now, I was wondering, is there any way I could save my text messages to my laptop, so my memory isn't full anymore, but I can still view them in the future?
I hope some of you people can help me...
Cheers.
Look up "Message Saver" or "Message Storer" apps in the shop: http://www.allaboutsymbian.com/shop/
Use either one to save all messages in a file.
Then use FExplorer (http://www.gosymbian.com/) to send the file to your PC over Bluetooth.
Alternatively, try "Desktop Message". Also from the shop above.
El_Thierro wrote:Hi everyone!So, I have a Nokia 7650, but it's memory is getting stacked with text messages... I don't like deleting them, and I have more then 750 of them right now... I also have a USB Bluetooth Dongle, which I use to send my images from my cellphone to my laptop...
Cheers.
Yes, there is no way to do this with the "native" tools and apps. that come with the phone, and prevously posted, you will need some third-party application to do this, or write one yourself.
N/A wrote:Look up "Message Saver" or "Message Storer" apps in the shop: http://www.allaboutsymbian.com/shop/Use either one to save all messages in a file.
Hello, I would like to ask a few question regarding the usage of MsgSaver 1.14, I managed to save the SMS into Notes. Using SeleQ, I'm unable to find the right file to be transfered to PC. By the way, i don't have bluetooth dongle so i will have to transfer the file from C:/ to E:/ using SeleQ, then copy it to PC via USB cable.I'm using Nokia N-Gage. Can anybody help? Thankyou.
