Volume in my 6600
9 replies · 2,363 views · Started 16 October 2004
The default volume is way too high for me. Can I change it to like 30% without having to do it every time i use it?
I dont think he is talking about ringtones.
RonenB, You should be more specific,i can only assume you mean the volume in RealOne or recorder? Which should stay at the last volume setting you used,(it does with v.3.42.1 anyway) unless this isnt the case???
Actually I'm talking about the volume in me earpiece. It is just too loud either in the phone itself or with my BT earphone.
Ronen as mentioned before in this thread you can adjust the volume of the profile you want by going to profiles=>personalize and then you adjust the volume as high or low you wish it to be!
I am sorry unless if you mean sth else than that!
Earpeice volume cant be adjusted in 'Profiles',but mine stays at the last used setting anyway,so once you have found a comfortable volume it should remain for all calls after. (Although it sounds as if yours is returning to max?). :con?
Ha ha,
I think there is a whole load of mis understandings in this thread Lol
What i mean is,the volume adjustment for the earpiece is set during a call by moving the joystick left and right,if it was set at half volume in the last call,it will be at half volume for the next.
But it sounds like yours is reseting to max volume each time if you have to keep lowering it.
Well my ear volume is always adjusted to the level i set it last time. Some ppl have loud voice so i have to decrease volume and some ppl have low voice so i need to increase the volume lol.
alexandra_v wrote:Well my ear volume is always adjusted to the level i set it last time. Some ppl have loud voice so i have to decrease volume and some ppl have low voice so i need to increase the volume lol.
So what you're really looking for is a phone (or an application for your phone) with fuzzy logic to control the earpiece volume level for you based upon the individual caller's vocal style...
