Do you know how can I add to the menu "Go to" any aplication I want to? For example FExplorer, or messages or guide or appman?
Thank you!
Thank you!
It's simple u have to just do these steps-
1- open the application which u want to add as a shortcut.
2- select >option>add to 'go to'.
3- press OK.
that's all.
Jazzy he is talking abt Application not abt the File.
ok dude/
thanks, but I knew that. What I want to do, is to add a shortcut to "Create a new message" or to FExplorer, or ANY app. I want.
it says on the manual that you can use the 'go to' option only on selected applications. so unless there's a third party software or something, and i haven't gone across one, you simply can't use 'go to' on any application you want.
You need an app called appman. It lets you add any app to 'goto'. It also does a bunch of other cool stuff. Great app. http://www.symbianware.com/product.php?id=appman60&pl=n3650. It dosen't list 7610 capability but its been working on mine for a while now.
Thank you, but appman only makes a shortcut to appman program itshelf, and I want ANY aplication shortcuts.
Uh no, try it again. 😉 Or take a look at the long thread on this 😃. http://www.allaboutsymbian.com/forum//forum/thread/29207/
I Think This Will Satisfy All the needs and the Title is more appropriate.
Thread Closed
