MMC compatibility
3 replies · 2,127 views · Started 17 October 2004
What MMC cards (besides the Nokia cards) do you use for a 3660 or 3620? I'm looking at getting either a 128mb or 256mb card.
Knoxzz wrote:What MMC cards (besides the Nokia cards) do you use for a 3660 or 3620? I'm looking at getting either a 128mb or 256mb card.
I just ordered Kingmax 256MB MMC Card Model MC-256M3 with PiP Technology from newegg.com.
The reviews of buyers indicated it worked wery well with Nokia 3650 and other nokia phones, so I assume it will work with my Nokia 3660 as well. I should get it in 3 days..I will post my findings.
The memory works without any problems...the phone recognizes 245MB..I am not sure if this is due to nokia format or because of my older firmware (V 4.57). I would say it`s the firmware
I am about to update my firmware anyways so I`ll see what that`s gonna do.. but Kingmax is definitelly a brand to go with.
BTW, this card is using PiP technology, it`s water and heat resistant and very hard to bend considering how thin it is...
I wanted to order some more, but they are gone now... 😮 i hope newegg will restock soon. :tongue:
