New: Yew Marquee - scroller for standby screen
0 replies · 6,323 views · Started 18 October 2004
Yew Marquee allows you to put a scrolling marquee on your standy screen. Feature inlcude choosing fonts, size, colours and position. You can use it to show reminders and any other text.
Author's Description:
Yew Marquee is an implement software which is used and implemented on the desktop of Symbian S60 Mobilephone. After running this software, there will be a rolled title on your Mobile desktop, and it can be used as memo and show the messages dynamically whereever or whenever. It can make your mobile desktop active and act as the screensaver as well. You can choose many fonts and style which you are most familiar with to show the title on your mobile tabletop. And support multi-languages. When some S60 users complain about the desktop of their mobile is not active, you can flaunt your pretty desktop of your S60.
Features:
* Max length 255 content
* Support Multi-Language
* Many styles of content to select
* Many fonts of content to select
* Shadow, Stroke effect
* Auto-Start
* 5 scroll speed
* Many motion style to select
* Posistion setup
* Smart Flush Screen(v1.02)
