Every text message I recieve on my 7610 seems to display the sender name backwards (i.e. Mobile Richard instead of Richard Mobile)
I have the contacts set up right whereby the name displays as I want it (set to first name last name) but for some reason it puts the second name first when it displays who sent me an SMS
Any ideas how to fix this anyone?
Thanks in advance 😊
James
just put the entire name under the default "last name" field
hawkerpaul wrote:just put the entire name under the default "last name" field
ahhhh, good thinking!! 😊
I'll ammend them all tonight using the PC suite
Thanks very much mate, much appreciated!
Goto contacts>settings>Name display............change this
akkies_2000 wrote:Goto contacts>settings>Name display............change this
That only changes how the contacts are displayed, not how the text message title is displayed unfortunately
yes it seems that option only applies to the display of the contact list.
seems the only way of doing this is to put full name in a single field - bit of a pain if you already got loads of contacts set up with separate name entries.
