HELP! How to get rid of the screen fading?
2 replies · 1,728 views · Started 18 October 2004
I would like to turn off the option (if that is an option at all) to fade into "dark" (not screensaver!!!) after a 10secs or so when you don't touch it. Is there an option (screen saver timeing is different so don't tell me how to change the screensaver timing. LOL)
Cheers,
No backlight timer that you can set. However, you can install, e.g., FExplorer or Torch apps and use them to keep the backlight turned on for as long as you want (for as long as you turn it off, or exit either one of these apps).
Both are free.
FExplorer you can find through http://www.gosymbian.com/
N/A wrote:No backlight timer that you can set. However, you can install, e.g., FExplorer or Torch apps and use them to keep the backlight turned on for as long as you want (for as long as you turn it off, or exit either one of these apps).
Both are free.
BEAUUUUTY MATE! Thanks... Now I can pet my 3d fishy more easily! LOL
And it's a really cool app too (I just have another post exaclty relevant to this explorer software... Files on the hard drive, what is important and what can be modified, deleted, etc... 😉)
MEGATHANKS!!!
P.s.: I've tried another file manager software but this one is waaay better. With the other one I couldn't even see all the files. Ohh, I'm soo happy! Ohh, my fishy is hugnry! LOL
