have not a clue about phones but want to get music for ringtones off my pc without cable lead any ideas appreciated
how can i get music to 6600
Wht Type of Music u want?
all sorts house etc
if you want them as ringtones you hav 2 convet them to .mid and send either by bluetoth I.R. or email them
hmm ok so how exactly do i email them? eg where to/an email address?
also is converting the .mid easy?
Unregistered6 wrote:hmm ok so how exactly do i email them? eg where to/an email address?
You can browse various wap sites for midis but if you want an audio sound you have to convert it to wav or amr (search the forum for this) first for you to be able to use it as ring tone, if you want to listen to a whole song or lots of songs, you would have to use a card reader or bt dongle or irda cause thats easier faster and less effort would be needed. (also read about mp3 compression as it will save you space and time uploading) I prefer the card reader.
Get an mp3 player as well.
Theres not much easy way around this but consider it an investment if you'll be buying the card reader.
Is 6600 support mp3 as the ringtone format? If yes, then how we can enable it? Becaused according to the user manual, it stated that in order to use mp3 as the ringtone, the mp3 must store at gallery->Digital sounds folder. I tried to created this folder in mmc and in phone as well, but I cant see this mp3 lar. Anyone can help?
The "digital sounds folder" where ringtones are searched is "c:\Nokia\Sounds\Digital" in phone memory, and "e:\Sounds\Digital" on the memory card.
