New: Psiloc Voice Reminder
0 replies · 4,851 views · Started 19 October 2004
Psiloc have announced the availability of Psicloc Voice Reminder. The program allows you to record voice memo, and then (optionally) associate them with a particular time and have them played back at that time (an alarm like function). Alternatively you can listen to all recorded notes.
Press Release:
Psiloc Voice Reminder - new application for Series 60
Poland, Koszalin, September 30, 2004
Psiloc launched today new application for series60: Voice Reminder.
Voice Reminder application is the easiest way to remember everything you need. It will extend your memory making your life more efficient while saving time and effort.
Say to the device microphone what you need to remember and then select time for the alarm event. Application will then automatically let you listen to the note just when you need it alerting you with selected sound that there is something you should not forget. You can set an alarm specifying exact time in future or by deciding after what time you would like to be reminded.
Note, without specified time the application will store the voice information. There is also an option to quickly listen to all recorded alerts to let you easily get informed about everything you planed to do or an option to listen just today�s notes as well as specified types of notes.
The application is optimised to save time while using it making it an ideal tool for busy or just �lazy� people. With its option to mark tasks as done it can be used as the classical TODO with the major enchantment that Voice Reminder uses your voice as input instead of time taking typing.
