Hiii
Following are the Two images they are the theme of Nokia 6630 and i have the one theme of the flower (www.symbianthemes.com) can anyone having the hand with butterfly theme or can any one make ir up.
Nokia6630 Themes Wanted
Elton U Make It Man !!
U're Genius !!
I'm interested in these 6630 themes ... as well as the default 6260 ones.
Thanks in advance ...
But is there any way to get the orignal in bulit themes.
There is. If i remember correctly, you had to copy the files from Z:/System Skins to your MMC card. Don't forget to remember what the folder's name was (eg "101F8688"😉
Then transfer those files to your PC via data cable, then zip them up with WinZip or WinRAR
nk_au wrote:There is. If i remember correctly, you had to copy the files from Z:/System Skins to your MMC card. Don't forget to remember what the folder's name was (eg "101F8688"😉Then transfer those files to your PC via data cable, then zip them up with WinZip or WinRAR
I have the mbm and the skn from the Nokia 6670. Can you make with this Files a Sis? Can you help me?
Mellie
Extract the Images from mbm using 'Mbm Wizard' and then re create the theme with 'Theme studio'. 😊
Wouwww:
Hey Mellie75 can you send me the mbm and the skn from the Nokia 6670 to my email account???
Thank you very much
[email][email protected][/email]
I would like to put the default 6630 theme on my Nokia 6600, is this actually possible?
I copied the default theme from the romdrive ( Z: ) of a Nokia 6630, copied the entire 101f84b9 directory to the MMC card E:\System\skins of my Nokia 6600.
When opening the 6600 theme manager I can see a new skin called 'default theme' on my MMC but when opening I see the default theme of the Nokia 6600 and not of the Nokia 6630...
Renaming the 101f8b9 directory to something else did not make a difference.
Opening the mbm files with mbm-wizzard did not work..
:con? :icon13:
The same thing happen with me but i was using 6670 and 7610.
But every time the i see deafult skin under that theme name.
but work fine in same phone
like if i copy from "z" and paste in "e" of the same phone it works but if i insert the same mmc in another it is the deafult theme.
Hi:
Can you send me the original 6630 folder to my email account?
I will built a .sis file....
I'd love to have this theme as well... if anyone has it or creates it.
Andrew
Here Is The Flower Theme of Nokia 6630.
Thanks mate! Greatly appreciated!
Wowwww
Thank you very much!!! Great work!!!
Mellie75 wrote:I have the mbm and the skn from the Nokia 6670. Can you make with this Files a Sis? Can you help me?Mellie
Sure I can help you, I can help make the SIS. Please send them to [email][email protected][/email]
Then I'll post back the SIS file 😊
nk_au wrote:Sure I can help you, I can help make the SIS. Please send them to [email][email protected][/email]Then I'll post back the SIS file 😊
Can you also help making sis files from some .jar games i have?? if so please add me at msn: [email][email protected][/email] THNX BY ADVANCE :P
Hey Vicky, have you built the Flower Theme of Nokia 6630, or do you purchase from website? :tongue:
If someone want to built another Original theme form 6260, 6670 or 6630, i can help them. Send me an e-mail!!! :icon14:
Bye
Sickogore wrote:Hey Vicky, have you built the Flower Theme of Nokia 6630, or do you purchase from website? :tongue:If someone want to built another Original theme form 6260, 6670 or 6630, i can help them. Send me an e-mail!!! :icon14:
Bye
Hi I haven't buy the theme nor i have made it.
i have just download it from symbianthemes.com
Can anyone mail the 6670 themes to me? if someone got them or had them made doing the rebuild - I'm on mac, so I have no theme editor 😞
- Lars
Hi:
Can you send me the original 6630 folder to my email account ? plz 😊
Sorry !!! :frown:
Hi:
Can you send me the original 6630 folder to my email account ? 😊
This mail... [email protected]
my email: eddy_mlshotmail.com
Can anyone mail the original 6630 themes to me.Mail [email][email protected][/email]ks
thanks
Can someone send the original 6630 themes to me.Mail [email][email protected][/email]
thanks
I dont know why everyone is posting their e mails in here,as no one is going to send these files personally.
If any 6630 owners want to send me the .mbm's for these themes then i will compile the .sis files and upload to our default theme section at ST. 😊
Here you have the original Nokia 6630 Theme Files:
I tried it on my Nokia 6600, but it doesn't work.
If anyone knows how to make it work on a Nokia 6600, tell it to us!
The 2 mbm files provided above do not include the theme images,only icons/masks.
elton wrote:The 2 mbm files provided above do not include the theme images,only icons/masks.
Hi, elton!
Have you compiled a sis with 6630 theme?
Does anybody know where I can take compiled 6630 themes?
