Anybody can help? My 9210 can't recieve and send any sms, I try to modify my sms setting and Note Not Found Appears. Please help and sorry for my bad english :cry: [/b][/list]
SMS Error
Some time ado I had some problems with this message too.
Try reinstall the app. It will work.
it happend to me before the the following is what I did, but becarefull coz you will loose all of your messages and e-mails.
in the Messaging, Menu ---> Tools ---> Message Storage.
press delete to remove all of the messaging info and then it will be fixed. For some reason the indexation of the messaging it seems to be currepted. and this process reset it to zero.
