Acrobat
9 replies · 2,228 views · Started 08 October 2002
I'm trying to open some pdf files with the beta version of the 9210 Acrobat Reader. But it crashes all the time: Kern errors.
Am I the only one?
I have downloaded the installer and launched 2 pdf files:
- the first one has loaded but probably not completely
"unsupported object found. Some contents may not display"
- the second one didn't load:
Application closed "Kern Exec 3"
Do you think it's a problem with my communicator or a software bug?
G.
Please excuse my ignorance: how may I control my firmware version?
Thanks, G.
Press *#0000# on the phone side
you'll get something like:
v 3.18 <<< firmware version
date
RAE-3
this is off-topic. But i remember on one of the threads here that you (Dazler) are still using v3.18? that's amazing... how many are still using this? just wondering. i believe you're satisfied w/ ur v3.18...
