Hello
Want to clear a doubt. I have N6600 and another family member has N6610. I have installed PC Suite for Nokia 6600 and bluetooth on my PC. I also have an IR port. Can I also install PC Suite 5 for the 6610? Will it in any way interfere with PCS for 6600?
Installing PC Suite 5 & 6600
You will have difficulties making both these PC Suite versions coexist.
Things are better with newer versions of PC Suite (6.x) for newer phones. If the 6610 is supported with PC Suite 6.4 (http://www.nokia.com/pcsuite), then you might be able to get it to work with the 6600 version.
N/A wrote:You will have difficulties making both these PC Suite versions coexist.Things are better with newer versions of PC Suite (6.x) for newer phones. If the 6610 is supported with PC Suite 6.4 (http://www.nokia.com/pcsuite), then you might be able to get it to work with the 6600 version.
I removed the PC Suite 5 and installed 6.4 and now both suites are working fine except that 6.4 identifies the 6610 as 7510. Any clue as to how that has happened? I can install the apps and all still. Just curious to know this anomalous behaviour.
