Hi!
I have a 300+ messages in my phone memory and what I don't like about it is that all my messages are left in my 3660 fone when I use a different mobile (with MMC slot). My problem is that how could I transfer ALL my messages in my folders and inbox from my phone memory to my MMC? Will the Nokia PC suite do any help about it?
Messaging -> Options -> Settings -> Other -> Memory in use: change from "Phone memory" to "Memory card".
if u have changed the memory from phone to MMC before, the phone will not prompt you to copy the msgs from phone to MMC.
To make sure msgs are copied from phone mem to MMC, first use FExplorer/SeleQ etc to delete everything in the E:\System\Mail folder. Then change the memory from phone to MMC in the Messaging app
rohitr=
to N/A:
I already did that way before, changing the settings in the Messaging app... but it only sets all the further incoming messages to the MMC... but there's no command that could copy all the messages that were already saved in my phone memory... only those messages that were stored in my SIM card... 😊 but thanks for your help anyway
To rohitkhannak
where can i download that app?
Euphora17 wrote:To rohitkhannakwhere can i download that app?
Well the best way is to search the forum. 😉
Wirelessly posted (Nokia3650/1.0 SymbianOS/6.1 Series60/1.2 Profile/MIDP-1.0 Configuration/CLDC-1.0)
You could download the FExplorer app from www.gosymbian.com. I would recommend FExplorer for it is a freeware, highly useful appAfter u have downloaded it, u will notice it is an app ending with .sis . If u have a bluetooth/Infrared connection, u can use PC Suite to send the app to the phone and install it on the phone. If u have a card reader, u can use the following format to install Fexplorer - 1) rename the ".sis" part of the file to ".jpg"2) place the file in the images folder and place the card back in the phone 3) use the messaging app to install Fexplorer- i) make a email acc (Messaging->New message->E-mail) if u dont have one already (it is not necessary for the entries to
Continued- be correct ones, just enter any junk entries) NOTE - u have to type an address in the address column, like [email protected] (the @ sign has to be there and the dot after that too) iii) Go to Options->Attachments->Options->insert->Image and from there go where u have saved the fexplorer file, and select it iv) after the file has been added, options->open v) the app. manager starts installing the app. after u have installed fexplorer, go to e:\system\mail, and DELETE only the items IN it! Then change from phone memory to Memory card in the messaging app. The phone shud prompt u to copy the msgs to the memory card, and then choose yes.hope this was useful, rohit
help me pls i got a proplem with my ngage left button ,what shall i do to change my bluetooth incoming files to memory card????????.
hi guys, I need help with my messages you see i have many messages in "my folders" located in both memory card and Phone memory . . . is there any way to merge both "my folders" or is there any procedure that would result in having both the contents of "my folders" in either the memory card or Phone memory.
By the way . . i got nokia 7610 . . .
thank you very much
