Hi, im new here and i need a little help.
I use Windows XP with not Service Pack.
I have Nokia 7610, i try to install the DKU2 Program from CD and...
"You need Service Pack 1+"
Anyone knows when i download old version for the DKU-2 Program for Windows XP with not Service Pack?
I Need Help Plz! (DKU-2 Problem)
Well if u don't want to install Service Pack.I think u can't use DKU-2 Or Else use Bluetooth it will work without service pack.
and about the old version u can search in Google
And also, get the latest PC Suite and included drivers (in PC Suite 6.4 package) from http://www.nokia.com/pcsuite (the one on the CD is already "old", both PC Suite and drivers).
I dont have Original Windows XP.
I think i cant not install the Service Pack 1, i need original cd key Windows XP.
I think.... Or not?
Tough luck. Buy a legal copy of Windows XP first.
their are programs available to change the windows CD Key although i would only ever reccomend changing to another valid key... ahem. anywho their are key generators available through p2p files ahring programs... its very difficult to generate a legal, non blocked code.
of course all this is just theoretical and would be illegal if you actually did it. u can get oem windows xp home/pro for �65/�95 if u look. which isn't that much for the amount of hassle it saves you.
Ok thanks guys...
Maybe i buy a Bluetooth 😊
I think is better.
