Hey, i juz bought an SX1 and when i connect the phone to computer using the usb cable...and try to open SX1 after installing the suit...it says that there is no connection to the phone....anyone...pls help....
I can't connect my phone to computer
same here, nobody helped yet
Hello,
Do you check System Requirements?
I had the same problem for my phone and some other usb devices.
I used WinXP+SP2 ,For Solving Problems I uninstall SP2
(opposite the Sys. Req.) and install SP1a and all problem solved!!
Regrads.
hi , i already use SP1a, still doesn't work.
Hello,
I see another post That you said about firewalls.Do you use any firewall?
If you used what is your firewall name?
Good Luck!
