Non working software
6 replies · 2,880 views · Started 22 October 2004
Anyone else found software that doesn't work on the 6260? So far I have
Readm
Active Day
Active Desk
AnswerMachine
Any others?
dkeppler wrote:Anyone else found software that doesn't work on the 6260? So far I have
Readm
Active Day
Active Desk
AnswerMachine
Any others?
also photoeditor,fs caller,camera fx,flexicam,video editor,photographer,agile messenger,rockit pinball,eti camcoder,photorite,psiloc e-recorder(it doesnt tape)in general all the camera apps dont work(most of them)
seeing as it is series 60 2.0 you might find the compatibility lists of the 6600 and 7610 to be helpful, as they run the same OS's (6260 is closer to 7610 in terms of operating system i think)
softwares work like champ on my phone... though it kind of strangely takes some time (like a minute or smth) to turn on my beloved phone 😉
But nokia is renowned of it's warranty... get your the operating system in your updated (it's likely that the problem is in the operating system), 'cause this model is new there are some bugs in the system... 😞
just me wrote:softwares work like champ on my phone... though it kind of strangely takes some time (like a minute or smth) to turn on my beloved phone 😉
of course there are also softwares (for 6600 etc.) that won't work on 6260... the operateng syste is a bit different... though usually softwares are universal.
just me wrote:of course there are also softwares (for 6600 etc.) that won't work on 6260... the operateng syste is a bit different... though usually softwares are universal.
Programs that works with Cam, Soundrec or Contacts will not work cause the different apis.
Mostly others should work fine.
ive testing some Progys 4 symbianware out:
only SA,FSC, black list, power recorder arent compatibel yet:
on the site of them u will find nearly each day more Progys for the 6260.
until now 16:
- Power lock v.1.02
- Sms machine v.1.02
- Sms Reminder v.1.0
- Power Car v.1.01
- Stacker v.3.00
- App.man. v.1.04
- File man. v. 1.02
- Multi clip board v.1.00 (i love it !!!)
- Power torch v.1.00
- Screen taker v.1.01
- Smart birthday v.1.02
- Smart crypto v.1.0
- SmartvCard v.1.01
- SmartvCal v.1.01
- Astronix v.1.01
- Power Ball v.1.00
regards S�mi
