Problem Syncing with Outlook 2003
5 replies · 5,001 views · Started 22 October 2004
I am having problems syncing my 7610 to Outlook 2003. I am getting a message that says "cannot open outlook" but my outlook is open and running . Has anyone experienced something similar ?
Costas
i use outlook 2003 and use Sync all the time...
haven't had any problems at all
EDIT:
than again all i use is the contacts and calendar...
How do you set up Sync ... so I can sync my 7610 with Outlook via Bluetooth (is Data Cable possible?)
Please help me ... I don't know how to set it up ><"
eg: What are the details I need to create a new SyncML profile in Connect-> Sync?
nk_au wrote:How do you set up Sync ... so I can sync my 7610 with Outlook via Bluetooth (is Data Cable possible?)
Solved Outlook 2003 problem by downloading patch SP1 from Microsoft web site.
I am syncing using the data cable. Have not figured out how to sync using Bluetooth.
Does anyone know ?
kapetac wrote:I am having problems syncing my 7610 to Outlook 2003. I am getting a message that says "cannot open outlook" but my outlook is open and running . Has anyone experienced something similar ?
Costas
Problem was fixed by downloading Outlook 2003 patch SP1 from Microsoft.
