kill bill theme for nokia 3650 ???
5 replies · 3,299 views · Started 22 October 2004
i have installed the kill bill theme on my nokia 3650 & after installing i cant find it?? can someone tell me if themes are ok on nokia 3650 & where do they install ??
many thx guys :icon14:
dcman wrote:i have installed the kill bill theme on my nokia 3650 & after installing i cant find it?? can someone tell me if themes are ok on nokia 3650 & where do they install ??
http://www.allaboutsymbian.com/forum//forum/thread/27216/
this topic has been discussed in the link above - summary : Nokia Series 6.1 phones (nokia 3650/3660/N-Gage/7650) CANNOT have themes, while Nokia Series 7.0 phones like Nokia 6600, Nokia 7610 CAN have themes. There is a project called themerizer, by jw, which allows you to extract bits and pieces from 6600/7610 themes, and export it into an SIS file which can be installed on Nokia 3650/3660/N-Gage/7650. It has not released yet, and will hopefully be released by end of 2004. themerizer site : http://themerizer.symbianthemes.com/
rohit
EDIT - The themerizer site doesnt seem to work right now though!
i heard it can be done with smartlauncher, i already have it installed so how can i luanch the themes with smartluancher,thx
Yes. you are correct. You can install a variety of themes which are available for smart Launcher only. Themes are available for nokia 6600 will not support smart launcher. I have a good collection of themes which are desighned only for work with smart launcher. i never tried before because i dont have smart launcher. if interested pls let me know.
baiju.
hey
i am interested in both the programe that u used and the themes that fits with the programes .....
