mp3 error
7 replies · 1,637 views · Started 22 October 2004
hi! when i get my mp3 on my n-gage trought usb...and i want to play it..it says system error! whats the problem! please help..i just bought my n-gage...second hand!
Try formatting your MMC and putting your mp3's back on. I had same prob and it seemed to fix it.
You might also have to format your phone memory..
Type *#7370# but beware, this will remove contacts and messages, and anything else stored on the device memory.
UnregAvatar wrote:Try formatting your MMC and putting your mp3's back on. I had same prob and it seemed to fix it.
well..i have an preeinstalled game on my mmc card..snowboarding...how could i save it ...somewhere! i mean will it work if i just copy paste it ,...or what..or do i have to have an installation file like on pc!
tnx
ceexofobia wrote:well..i have an preeinstalled game on my mmc card..snowboarding...how could i save it ...somewhere! i mean will it work if i just copy paste it ,...or what..or do i have to have an installation file like on pc!
tnx
Just cut/copy and paste the entire floboard folder to your PC.
If you put it back to the same location at a later date it should still work fine 😊
thanx dude..i'll try that right now...and will inform you if it workes
jas0nuk wrote:Just cut/copy and paste the entire floboard folder to your PC.
