A925 headset sound bug
3 replies · 2,663 views · Started 22 October 2004
I have an A925 with firmware 30.80.20. When I remove the headset plug and put it back in again, I only get sound in my right ear! The only way to get sound back in both ears is to reboot the phone. Have any one else experienced this annoying bug?
I had the same problem...
The problem was that I have'nt plugged the headset in correctly.
Try unplugging your headset and the n plug it in again, a little harder this time..
Hopefully it will work now... 😊
No, that's not the problem, it's definitly a bug in either the firmware or the sound player program. I found a workaround to not have to reboot the phone though:
when you only have music in one ear:
1. stop the mp3 that's playing.
2. unplug the headset.
3. start the song again.
4. plug in the headset while the mp3 is playing.
TropicalFish! wrote:No, that's not the problem, it's definitly a bug in either the firmware or the sound player program. I found a workaround to not have to reboot the phone though:
This does not work for me, I have to reboot the phone. Can it have something to do with the UltraMP3 app?
A strange thing is that when the phone was new I had no trouble with it!
