6260 Internet
4 replies · 3,335 views · Started 23 October 2004
Does anyone know how to let 6260 surf internet use ur pc internet connections?
I see that 6600 have software to support that but I hope the software will release soon for 6260.
kkboy wrote:Does anyone know how to let 6260 surf internet use ur pc internet connections?
So do I, Im not sure whether this will be possible because the 6260 doesn't use a bluetooth serial connection.
I really would like to use this option too, but how? help! anyone?
I found this:
http://www.howardforums.com/showthread.php?s=&threadid=397875&highlight=%2B7610+%2Band+%2Bbluetooth
I'm not sure if it will work on 6260 as yet. You have to go to Phone Settings => Connection => Access Points. Make a new one and some fields mentioned in the tutorial are in the "Advanced Settings".
I'm stuck on a step. My computer's modem settings hangs everytime I try to open it. If someone can get it work work with the 6260, I wouldn't mind re-installing my XP to get it working.
Good luck,
-Nay
Thanxx for the great link...
As I tried to establish a bluetooth internet connection between my 6260 and my pc I found out the connection mentioned in the tutorial (see link above) uses m-router.
Nokia 6260 doesn't seem to use the m-router app / routine (whatever it is) anymore, where the Nokia 6600 does seem to...
However, in my opinion we have to try to find another way...
A good reason for it, not just because it's great fun 😃 , is:
Whenever I'm in reach of my bluetooth enabled pc, I want to recieve all new incoming mails, so I don't have to spend minutes recieving them through an expensive gprs or gsm connection.
There must be a way...
Let's find it!
Hahaha... 😃
