Ok i have made posts before saying that i get free access to Optus yes info internet...
I am on pre-paid and understand that i should not be able to access the internet at all. Well i have no special settings and i can still use it! however, i put the sim card in another phone and the internet wouldn't work, it said Check IP.
So i am starting to think that the n-gage qd can bypass IP security??? if anyone got an optus sim and a n-gage qd try connecting to Yes info internet.
ok post ur comments here
mysticfire2 wrote:Ok i have made posts before saying that i get free access to Optus yes info internet...I am on pre-paid and understand that i should not be able to access the internet at all. Well i have no special settings and i can still use it! however, i put the sim card in another phone and the internet wouldn't work, it said Check IP.
Well, I don't think Nokia would have made the N-Gage as a hacking device.. but it may be the way it connects, and the used protocols that affect whether the IP is checked or whatever.
Jas0nuk : ??!! Isn't that pretty obvious. Besides you can't just go on using any protocol you wan't, the service must support it.
mysticfire2 : Which another phone did you put the sim card in? I'm making a guess that it wasn't an Ngage.
Just insert the same simcard in another ngage :
1. If the net works then probably, yes the Ngage can bypass ip checking.
2. If it doesn't then I guess the card works only with the registered IP or the registered EMI, whichever applicable.
Heh Heh.
I also get free internet on my optus prepaid using "yesinfo internet"... 😃
But, my friend with a normal n-gage cant seem to get it, i use an n-gage QD.
It's pretty cool, really. Add me to msn: [email][email protected][/email] so we can discuss this further
H4rsh wrote:Jas0nuk : ??!! Isn't that pretty obvious. Besides you can't just go on using any protocol you wan't, the service must support it.
Just pointing it out to avoid the risk of any dellusions 😉
Omg have optus finally woken up to themselves and fixed their bloody prepaid 'free' gprs problem? Is there anyone that can't get this free anymore??????? Because i dont think i can :/ THERE MUST BE A WAY TO GET FREE GPRS AGAIN!!!!!! Anyone.. Anyone????
Does anyone know of any contract plans in australia that offer unlimited gprs? or a free amount of gprs per month or something? thanks... Im sad that my optus internet aint free anymore 😞
Im Very Sad Please Someone Anyone Help Us!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Aghhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
