help with my n-gage
5 replies · 1,549 views · Started 23 October 2004
HELP!! ive downloaded loads of my games on my pc. i was gonna use pc suite for the n-gage but it DONT work for sum reason. So wat i do is open the files from the pc when i link the n-gage using a fire wire. The only problem is i dont know which folder to put it in. Please Help
get fexplorer, an MMC, and a card reader
otherwise just fexplorer. you need the .sis files, and they have to be series 60
If you're trying to use your N-Gage with the PC Suite..it doesn't work.
Nokia made it that way. But no-one knows why. It just doesn't work.
Don't put them in any folder. Just copy paste the sis files in open in the root directory.
Once you've done that, disconnect firewire properly and install the game you copied by running their setups from "Manager" in "Tools"
jas0nuk wrote:If you're trying to use your N-Gage with the PC Suite..it doesn't work.
The USB cable connection with the N-Gage accesses only the memory card. The Nokia PC Suite for N-Gage works with Bluetooth (and allows phone memory access).
N/A wrote:The USB cable connection with the N-Gage accesses only the memory card. The Nokia PC Suite for N-Gage works with Bluetooth (and allows phone memory access).
Oh damn, sorry I meant with the USB cable
Forgot to make that clear. lol. 🙄
