9210i PC suite and Windows XP SP2
6 replies · 6,172 views · Started 23 October 2004
i have to format my pc. when i installed it, no problem was encountered. not until i have to transfer some word files and excell files. it seem to work at first but when prompted to choose convert (which i did) nothing happens.
btw, i enountered some problems on the installation, didnt bother to write it down but as far as i remember, something about registration failed or something...
can anyone help me please
thanks!
The only thing I can tell you is that there are many people out there facing same problem as you but not resolve yet.
9500 is already out on the street, Nokia does not seem interested in solving the problem.
Sean
NTunregistered wrote:i have to format my pc. when i installed it, no problem was encountered. not until i have to transfer some word files and excell files. it seem to work at first but when prompted to choose convert (which i did) nothing happens.
thanks!
😛cguru: :rock: :rock: :rock: :icon14:
I can't help as I face the same problem also. But I did write down the error message:
Error in Self-Register:
C:\Program Files\Nokia\PC Suite for Nokia 9210i Communicator\Agnssnc.dll; C:\Program Files\Nokia\PC Suite for Nokia 9210i Communicator\Psiocvif.dll; C:\Program Files\Nokia\PC Suite for Nokia 9210i Communicator\Psisht.dll; C:\Program Files\Nokia\PC Suite for Nokia 9210i Communicator\Psiword.dll
Anyone can help??? Thanx!
this is good ...
perhaps someone with a working (no error messages receieved) communicator program in their PC can help...
run regedit.
search for the files that was posted above.
and post to this forum how many instances and commands that came with it.
am sure this one can be manually solved.
You need to register those files manually using:
regsvr32 <path+filename>
where <path+filename> r:
do one file at one time.
HOpe this help. TQ
***Anuar/-
