3650 showing "App. Closed main E32 USER-Cbase 21 !" Error.
6 replies · 4,800 views · Started 24 October 2004
When i switch ON the mobile some times getting an error message like " App. Closed main E32 USER-Cbase 21 ". Is it any serious problem? because so far phone is working good even with the above error.If i press OK then error has gone. Thing is that error not showing frequently.Why is happened any idea?.
Befor i installed too much warez and phone gets highly disturbed.Some times phone does not startup too.But after uninstalling all the warez it working very good. nows its a warez free mobile.
Regards,
B
Wirelessly posted (Nokia3650/1.0 SymbianOS/6.1 Series60/1.2 Profile/MIDP-1.0 Configuration/CLDC-1.0)
I used to get that error too, but it really made no difference cause the phone still worked. I think this error occurs if you switch off the phone while some programs are still running.Ever since i did a hard reset , i hardly get that error anymore though. Rohit
delete the system.ini file, then restart your phone, a new system file will be loaded from the ROM drive and that will solve your problem.
I'm really affraid to delete system.ini. because if anything gets wrong its very difficult to get the proper service here. Are you sure it doesnt make any problem or just kidding...?
baijunj wrote:Hi,
you might wanna try to back-up the content of your phone to PC and do the hard reset (*#7370#)
It fixed my problem, when I could not start my nokia 3660 (app. was closing my startup all the time. )
deleting the ini file worked for me, i assure you im not joking, been on this forum long enuf to know what im talkin about but if you dont feel sure then take it to an expert.
sak
Ok friend. I will check out and let you. See actually thing is that here i never get a proper service for nokia. Thats why I'm little affraid. Anyway Sorry for the trouble.
BAiju.
